Re: Which small 4 stroke is best for the $?
Hi Trapper,<br /><br />Check out the Mercury Bigfoot four strokes. (9.9,15,25,40,50,50) They have a real beefy lower end similar to a mid range even the 9.9 unlike the spindly standard lowers of all makes.<br /><br />The larger props on these motors are closer to a larger anti-cavitation plate witch helps to keep air out and traps water in providing better thrust, torque and speed for the HP. The shaft and gears are about 30% larger and prop 20% larger.<br /><br />Comparing website to website specs the Honda 25 and the Merc BF 25 WOT (max RPM) for Honda = 275 lbs of thrust and Merc 400 lbs of thrust.<br /><br />This info is a little dated I had compiled it when I was considering getting a new 25 for a jon I own. I think the specs were for the 2002 line though. Check it out dont take my word for it.<br /><br />It's worth looking at either on the net or better at a dealer. This was my first REAL look at the 4 strokes. Being used to the sound and smell of twos, The first one I looked at was Honda and when the guy started it up inside the bldg I was impressed quiet no smoke, very nice motor. Mercs also quiet and no smoke but that heavy duty Bigfoot has a lot going for in since most people will push their smaller boats pretty hard, at least I have.<br /><br />Never got either motor decided to keep what I had and spend the money on another boat (so I wouldn't have to push the little ones as hard)<br /><br />One other issue I see mentioned here a lot is the dealer support. Ive not had many problems with my dealer. But Ive read about nightmares with some dealers. So the general consensus of the board is that this is a major factor in what brand you purchase.<br /><br />Sorry I cant give you first hand on the water info or long-term durability performance but its first hand research info for what its worth. Maybe someone else will have something to say about the Bigfoots, good or bad.<br /><br />Good luck
