Which spark plugs
Dhadley
Re: Which spark plugs
The lower octane is whats recommended no matter what spark plug you use (with stock compression). I prefer the cooler plug simply because theres less chance of piston damage.
rickdb1boat
The higher octane actually burns cooler, so you would be right back where you started if you use a hotter plug and higher octane. Dhadley is right on it, as usual..
