which stator works?
prolinews
I'm trying to put a V/6 back together after some fire damage. I'm not quite sure what year it is the power head is from a different mid section so the serial#s mean nothing the welch cap only has an 8 stamped in it.it has (v225) cast into it on the # 6 cylinder but the bleeder lines hook up like a v200 or v150 I'm replacing the entire electrical system the only items I dont have are the stator trigger and rectifier. none of these have part #s on them . the stator only has an 8 and 81? what trigger stator and rectifier will work on this motor . I can put these back on but would rather have the reliabilty of new parts with un melted wires. I have pics but don't know how to display them.
Laddies
Banned
Re: which stator works?
there are about four differant combinations, with out a serial number I think you need to see a dealer so they can look at the parts
rabidfish
Not only that, but there are different stators for some of the engines depending on the flywheel.<br /><br />Some had to be literally measured ( either 1/2 or 5/8 laminate thickness ) You'll need to be able to measure the old one.<br /><br />Email me your pictures directly...
prolinews
Got a CDI unit from Rapair that is suspose to work it replaces about 12 p/ns Going to put it on tommorow.
prolinews
sure hope it works. This motor has made many people scratch their heads . not a usable P/N anywhere. the only thing is the cast (v225) on the # 5 cylinder so it might be a v225 or a v200
prolinews
It might be one of those lake x motors. nonproduction motors are notorious for mix and match parts I plan on giving them a call or going down there and see if they decode it . My local dealers are at a loss with this one.
