Re: Which tachometer for an 85 'Rude 90hp?
You need a tachometer that can be set to 6 pulses. If you have the Evinrude/Johnson side mounted remote, it has a plug for a harness that comes with the correct OMC/BRP tachometer from a dealer. The Faria and Teleflex tachometers work the same if set for 6, but you will need to buy or make a separate harness.
