- Joined
- Oct 25, 2011
- 25,354
Re: Which to do first?
When you are grinding, Slim may be correct & the filter may clog & become more difficult to inhale. Excercise caution & err on the safe side, replace them as often as you can during the grinding stage. The actual fiberglass & polyester resin stage will be much more difficult for you to 'sense' that the filters need to be changed. The fumes shouldn't clog the filter in any real way to restrict inhalation, it will just lose it's ability to keep the noxious fumes away from your lungs. This is usually about the time you can 'smell' the poly fumes while you are wearing the mask. You should exercise even more caution if you have limited olfactory acuity. If it is a general limited ability to smell odors, be extremely diligent about wearing your mask and changing the filter media often. By the time you can detect the polyester smell, you may have already inhaled a higher then normal exposure to the fumes. Is it lowered ability to smell most odors, specific odors, or until the odors are what most would describe as strong that you are able to detect the odor at all?
If you are able to work in 6-10hr chunks while wearing the mask, you should consider changing the filter every time you work on the boat. In smaller work hour increments, you might replace them every 2nd or 3rd time, or at about the same time period of actual filter usage.
Compared to your health, filters are cheap. Even if replaced every 4 or 5hrs of usage.
Best of luck on your project, and I hope your stay in dry dock is short & rewarding
I hope I can smell the fiberglass when it gets bad. I had a firecracker accident when I was a kid that left my olfactory sense a bit numb.
