Which type of plywood should I use?
Zq8 Blazer
I have a Monark 1660 Jon boat and I don't use it a lot(maybe 3-4 times a year), but the deck on it is very small and I would like to extend it so that I can mount a seat up front. Should I use marine plywood or pressure treated plywood with a lifetime warranty? I know marine is probably the best, but with it seeing as little use as it does I didn't know if it would be worth the extra money.
Exterior grade ACX.
Dont use pressure treated on aluminum. The chemicals thet use to treat the wood will corrode the aluminum
You only need the 1/2 thick, however yes. Menards premium is araucoply which has more thinner layers resulting in more strength
