sutor623
- Joined
- May 23, 2011
- 4,089
Okay fellas my lower unit project is nearly finished. I am assembling the water pump now. Here is a pic of the three waterpumps that I have.
The first one has no grommet at the top where the shaft goes through, and is plastic. The water input tube is messed up because some genius tried to shove it up without the water input line in the right place.
The second one is aluminum, and my preferable choice, since the base that I'm using is aluminum, but the rubber grommet used at the top has a little tear in it, but nothing that would create a leak.
The third one is the new 'el cheapo' that came in my kit. It has no rubber at all at the top, and there is a gap between the metal and plastic on the top. It seems almost impossible to me for that housing to create a vacuum.........
None of these pumps seem to be snug around the driveshaft. There is a rubber piece that goes over the top of the waterpump that helps with that. My question is, if it was your motor, which housing would you guys use? I thought that the tops would sit a little tighter around the driveshaft, but I guess when the impeller goes in it prevents any leakage from happening when the vacuum effect starts with the water?
