studlymandingo
- Joined
- Mar 22, 2006
- 2,716
I have an 18'6" Winner Center Console with a 1986 150 Mariner V-6. I am currently running a 21p stainless Rapture prop that is vented.
With 2 adults an 85lb dog, 40-45 gallons of fuel, and some ice and liquids in a cooler, I am getting 43-44mph GPS. The RPMs are right at 5200+. I feel that I should be trying to get a little closer to the 5800 RPM range. My hole-shot is fine, I have Smart Tabs installed and she jumps the wave and is on plane in seconds. The A/V plate is level with the bottom of the boat, I don't experience any prop blow when trimmed out fully, and I'm getting 15-18 psi on the water pressure.
I'm thinking a setback/jack plate may be good for my rig. I have seen this hull come from the factory with a 12" setback so I think it might be good for the handling in rougher water anyway.
My question to you guys is... What do you think, should i step down to a 19p, or should I be looking at raising the motor and possibly stepping it back off the hull a bit?
