white discharge
fisheymikey
I have a 125 force
after running it for a while in the big bin of water I get a white greasy residue in the bin
should I be concerned??
mike
adamjr
Re: white discharge
Completely normal. Keep in mind that you're mixing oil with gas and the result of that combustion mixes with the water used for cooling. This is what you are seeing.
jerryjerry05
Re: white discharge
Check the lower unit for water in the oil.
If it's ok then like admjr says, normal.
When you check the oil?
Make sure you don't remove the slotted screw on the side of the lower unit.
81 charger
Re: white discharge
like jerryjerry said check your lower unit fluid for water in it. i had a bad seal causing the same problems but i did have some water in the lower unit
good luck
fisheymikey
Re: white discharge
I added oil to see.. the oil inside is not as clear as the one I added is a bit witish... is that normal... I have done 10 hours on it
mike
