Who made the Mercarb for Mercruiser?
IanFS
Hi Guys
Does anyone here know who made the Mercarb for Mercruiser engines? A customer service rep from Mercury, Fond Du Lac, emailed me that it was Nikki, but I have e-mailed them with no reply and I cannot find any reference anywhere that they had anything to do with it.
Any idea's?
midcarolina
Does the answer depend on someone winning a bet? or are you looking for replacement parts?
achris
More fish than mountain goat
It's a Rochester look-alike... Apart from one idle mixture screw (Rochester had 2) and a few other minor differences, they are the same.
IanFS
No bets midcarolina, still cannot find a Power Piston/Power Valve Actuator without buying a recon carb, so a £10 part I can get for a Rochester is about £300, but I'm told the dimensions require a new manifold as well.
Hi Chris, it is a Rochester lookalike but there are differences and the rest of the carb is fine. I've got a local engineering works who could build a Power Valve Actuator for a small amount but don't have anyone who can give me specs.
Looks like it will be a remanufactured Carb from somewhere. :blue:
midcarolina
Ahh......... was that your thread I remember about a missing PV actuator? It;s a shame you can't find a boat yard that has a junk mercarb you could grab.
IanFS
Hi thanks fastatv, yes I mailed them because they sell a Power Piston for the Rochester at about $10, so because I had read the Mercarb was a Rochester copy I thought it would fit, but when I checked the dimensions and then asked them it was a no!
This is possibly one of the most frustrating things that's ever happened, I even triple checked my garage in case I had done something really stupid when stripping the carb and maybe didn't notice it, but as I took pictures and am the careful sort (anal retentive I've been told) I know it definitely wasn't there. Was it there originally? Has the carb been changed at some stage before I bought her, I dunno, but it looks like I'll have to buy a part which is 10 times the price just to have it working correctly.
Thank you all for your help, it is much appreciated.
Fastatv
Hi English, I have some questions for you.
- How long have you owned this boat,
- Did it run great maybe a year or two ago
- For you to build the carb..what were the symptoms
- Are you 100 % certain that the carb came with the actuator
- Have you tried the carb since you rebuilt it
I asked you some of these questions because if my memory serves me correctly, the power valve actuator is "staked" into the air horn, and is not normally removed on a rebuild...and actually not removable. This make me wonder if the carb came with it.....I imagine it did, but still makes me wonder.
IanFS
Hi Fastatv
1/ 6yrs
2/ Yes, I could get at least 50 out of her at WOT when I first got her. I've had it serviced by several different people because I kept her on a trailer at a marina and I have wondered if someone had switched the carb.
3/ I had a drive bellows go on me which let in sea water, which in turn caused the Gimbal Housing to corrode quite badly. I was about to have the engine taken out at a cost of about £2000 and have the Housing replaced when I found a welder who welded in a bead. It was out of the water for a while, I stupidly ran it on the old fuel so decided to do a carb rebuild.
4/ Actually no I'm not entirely sure but I can honestly say that it wasn't there when I opened it up. As you say they are staked in.
5/ Yes I've been out several times. She runs OK, there's a little misfire at tickover but not much, however she won't run at WOT. She'll do about 30-35 and then struggle.
I have to say, the hole where it is supposed to be doesn't look as if it has ever had a stake chipped into it, however there was a Power Valve in it, which was replaced. Not being a Carb expert I started to wonder how the Power Valve worked so looked into it. The Sierra diagram which came with the kit didn't show a Piston, but the Adobe Mercruiser Manual shows it in the Carb breakdown pictures but again not in the Schematic.
IanFS
Thanks Rick, reply pm sent. :)
I'm now interested to know if there could be a batch of these carbs out there, I had someone else pm me with the same problem? Anyone else found the Power Piston missing?
