who sells thru hull kit for 4.3?
zackm58941
I have a 96 starcraft 1810 and want to put a thru hull exhaust on. just want to make noise. did some searching and cant find anyone who sells the kit, anyone have any ideas?
Cpt D
Re: who sells thru hull kit for 4.3?
Why would you want one??? They sound like a fart in a beer can! I love my 4.3, but I know I would hate it if it had though hull exhaust. Save everyone else on the water and abort your mission!!!
xsyourrides
Don't do it ,My boat had it on it when i bought it sounds horrible on the water. Its no v-8 and yes i do agree a fart in beer can. Put it back to stock as soon as i got home.Just my 2 cents
fossill
Around here they are banned from a lot of lakes. Gives boaters a bad name to the non boating public who are trying to close up launches and access to some lakes.
cr2k
Don't do it. But if you do, just buy thru hull fittings and flappers and some hose. You may need to get new elbows 90 instead of 180s. Then you get to cut holes in your transom. Can you feel good about doing that?
45Auto
That should have been a clue .......
wire2
Most stock 4.3's make an obnoxious drone when heading away from a listener, even at half a mile away. Thru-hulls will only make it louder. There's no noticeable gain in power or performance.
But if you're still determined to experiment, Google "Gil Marine".
Ayuh,... There's No Kits, you buy the parts, then put it together....
Btw,... A V6 on straight pipes sounds like a Cessna 152 at 3000',.... Sorta like a droning fart....
Don S
Idling on a hose backed up to a fence is one thing, the sound out on the water on plane at rpm, and under load is completely different.
