Rick Stephens
Thread starter- Joined
- Aug 13, 2013
- 6,118
Trying to figure this out. Swapping out an Alpha1 to a GenII. Bottom bolts on the Alpha 1 transom plate to gimbal housing are steel. On the GenII the bottom bolts are aluminum carriage bolts with a itsy bitsy rubber washer to keep water out of your transom.
On donor boat those aluminum bolts were pitted and corroded and one of them, when trying to unscrew the nylock nut, broke the bolt very easy. Makes me think this is some sort of shear bolt to protect the transom plate if you hit something?
In the first photo you can see the new OEM bolt from Merc alongside the pulled bolts. Left hand bolt has the little rubber washer on it. I'd like to know if one should fill the bolt hole with 4200 or similar to keep water from intruding past that chintzy rubber gasket.
Appreciate the thoughts.
