Don S
- Joined
- Aug 31, 2004
- 62,321
Re: Why are impellers....fragile?
So! Should everyone change to a Cobra drive that isn't manufactured anymore.
Guys, with a bit of preventive maintenance, and an alarm system, and watching the gauge, the impellers are fine. They are not that fragile. Many run them for 10 years and brag, actually they are just lucky. but the do not often fail for no reason, and most plastic bags just slow down the water flow and may overheat the engine but not destroy the impeller.
The whole idea that it's fragile is crazy, it puts up with a lot, but it is also inexpensive compared to the alternatives.
The impeller on the Cobra outdrive is relatively easy to access. Remove the rear cover and it's right there. Don't have to drop a lower end.
