Why can't I find this part?
2kvert
Ok guys I'm feeling inept and need your help.
I broke this tube wrestling the lower unit. It's a pretty straightforward simple piece but I can't find it online or know what it's called? It's just the water tube that has 2 oringgs on each end for the lower unit on my 2014 250ho.
What is it called and where can I get 1?
Thanks
Fun Times
What is your engine “model number” as it may help locate the correct parts.
clemsonfor
Have you looked up your engine on any of the parts sites that pave the parts diagram? They don't offer one? If not take the part number and go to eBay and put it in and see if you can buy a used one.
2kvert
I've tried but coming up empty, I'm sure I'm doing it wrong
2kvert
And apparently there can be 20 25 or 30 inch engines. Where do I measure?
tphoyt
Google decoding Evinrude model numbers.
Your leg length will be revealed in the number.
2kvert
I still can't find what the thing is called or where to buy it
2kvert
Well I ordered the parts , I thought but got the wrong things. I still don't even know what to order. Does anyone know what this is called?
Crosbyman
if all else fails have you considered having one duplicated ...a local mill shop may be able to " turn " one on a lathe....the design seems simple enough. good project for a local trade school.
Honorary Supreme Mariner
Item #27 on the parts list.-----3 different ones listed depending on whether a 20 " , 25" or 30" motor.-----Or contact----evinrudeparts.ca-----good folks there.
