Why did OMC like the number 8?
Status
Not open for further replies.
jrs_diesel
Just a curious thought that occurred to me. I see lots of posts here about 18, 28, 48, 88, etc, HP engines. Why the number 8 instead of an even number? Just seems a bit odd to me.
JB
Re: Why did OMC like the number 8?
Last time I looked 8 was an even number. :)
Each of those engines was a lower price version of the outboard rated 2HP higher. They "derated" them only 2HP so they still met the spec without actually detuning them.
So, the 18 was a 20 less some feature(s), the 88 was a 90, ,etc.etc.
yorab
Ensign
Also note: "seems a bit odd to me." :)
But seriously, that's quite a sneaky manuever.
boobie
The "8" numbers had less goodies on them and were strictly a sales pitch thing.
emdsapmgr
Boobie's right. The same engine as the 2 hp higher engines. They did not have VRO and usually did not have power trim. Sold as an inexpensive alternative, to hold the sell price down.
jrs_diesel
That makes sense. Thanks guys :)
Doesn't seem so odd now :D
Chinewalker
All true, with the exception of the 18. It was never a detuned or derated anything. It started life in 1957 as an improved version of the 1956 15hp. 2 more cubes helped it make 3 more horses. It simply wasn't strong enough to warrant a 20hp tag, but it was certainly stronger than the 15 it replaced, so it was designated an 18...
1946Zephyr
I think the later 20hp is just an 18 with a slightly larger carb, isn't it? The carb on the 20 was 379032 and on the 18, it was 278402.
As far as the 28 goes, (1960's) that was basically a re-birth of the 1956 30, with an updated fiberglass cowling. Cubic inch displacement was still the same, but there was a different carb here too.
It looks as though, "de-tuning" was just a form of reducing the venturi size of the carburetion. Kinda like in the 9.9's and 15's of the later era.:cool:
seahorse5
the 18 and 20hp motors have a funny history. OMC had the 18hp since 1957 and in the '60's Johnson bumped it up to a 20 at the time by using a higher lift reed stop and carb work. Ralph Evinrude was the head of OMC at the time and he insisted that the 18 remain in the Evinrude line-up as it was so well known over the years. So there was an Evinrude 18 and a Johnson 20 for several years.
1946Zephyr
Yep, I figured it had to be in the reeds and carb. I find that the 18's and 20's ran together, from 1966 - 1973. In 1974, both were discontinued in favor of the smaller 15's and the (still yet 22 cubes) 25 continued on till 1976. This marked the end of the classic split case lower unit, which was started in 1949 on the old Johnson QD-10 and 1950, on the Evinrude Fastwin 14hp.
In 1977, the classic 22 cube design was dropped entirely and the 25 was redesigned as a lower rpm 31.8 cube.
Joe Reeves
And all along I thought it was just a mathematical racist thing they had against numbers 7 and 9. :)
Dhadley
They were the first Dale Jr fans.......
montff77
EDIT: Hijacking a thread is a no-no, montff, particularly if it is an old, dead thread.
kfa4303
Banned
I believe they did a similar sort of thing with some of the big twins too. I had a '66 33 hp, which always seemed like an odd hp rating to me, but I think it was really a "detuned"/budget 35 hp. It didn't have a thermostat or a couple other little things, but it was electric start and overall a pretty awesome, super strong motor.
JB
Old thread, kfa.
Status
