bradleeson
Thread starter- Joined
- Mar 9, 2008
- 105
Bought a 16' Starcraft with a 1982 Evinrude 50hp. Replaced the plugs and the lower unit gear lube, and seals on the two bolts. Get to the lake, and she fires up beautifully. Get moving, switches into reverse and forward well. Top speed seemed really slow, but I figured that much just be the way it is?
After going awhile, I start to hear knocking; I turn to pull into a cove to check it out, and as I turn, CRUNCH, the lower unit just goes. Whining and grinding. Get back on kicker, and get her home, and of course little chunks of metal in the gear lube. Any idea why? Just happened to wear out? Water leaking in somewhere? It did not seem to have water in the lube when I drained it though?
Bummed, and Confused
Thanks for any thoughts.
