Re: Why do I/O's have short engine life?
Also, compared to cars, boat engines' exhaust manifolds are usually very thick, heavy cast iron which also helps to smooth out the temperature fluctuations.
Boat inboard engines (shaft and I/O) do indeed have thermostats, typically set to open at 140 to 160 degrees. The fuel system is tuned to burn clean at those temps. A close eye on the temp gauge will show that the thermostat cycles fairly quickly as it opens to allow cold water in, then closes to maintain engine temp. Mine typically drop 5 degrees or so, then recover.Car engines have a thermostat that keeps them the same temp all the time. I don't think I/0's have one, and if they do, they're not as efficient as a car's thermostat in maintaining temp.
