Re: why does my motor keep conking out?
If this were my engine with those problems, I would:
1. Make sure I have a Fuel/water separator with a clean filter (even new fuel can be bad)
2. Rebuild the fuel pump with a new diaphragm
3. Fully charge the battery.
4. Tap the carbs with a screwdriver to make sure floats aren't stuck closed or open. Or preferably take the carbs off and rebuild.
5. Take out the spark plugs and inspect, replace if fouled.
6. If these all fail, then I would look at the ignition system. Switch boxes are $100+. You can do all of the above for under $50.
