Re: why don't boats have transmissions?
I'll try make this easy (maybe) in two steps...
1) Props don't coast, so if you changed gears, the prop would slow down so much in the split second between shifting gears that you'd lose enough speed that you'd have to start back at the gear you just shifted out of.
2) You can only spin a prop (or any object) so fast through water. If you keep spinning a prop faster and faster through water, it will eventually cause cavitation and prop blow out. If you throttled up your engine to the max and decided to "up-shift" to a higher gear to gain more speed like on a car, you would have to first overcome step 1, which is difficult, and if you did, you wouldn't have very much speed to gain before your prop cavitates and blows out.
Hope this helps.
Hope this helps.
