Why don't sea choice 1 1/16 seals fit?
ba_50
The bearings in the 1 1/16 53541 kit are correct but the seal l44610 is too small. It won't go over the axles shoulder. I contacted sea choice twice but never got any reply.
Aren't all 1 1/16" axles the same?
Thanks
dingbat
Seems like a weird size kit.
Typically the inner and outer bearings and seals are a different sizes.
Do you have a picture or part number of your old bearings?
jlh3rd
"Typically the inner and outer bearings and seals are a different sizes."
not necessarily. For smaller load bearing axles the spindle can be straight, not stepped.
My axles take the 1 1/16 " bearings. #44649, inner and outer.
the seals can be a problem as I have experienced. There seems to be 2 different seals with the same outer diameter but different inner diameters because some straight spindles have a different inner step. One is 1.25" inner, and the other is 1.5" inner.....so you have to measure the old seal or get a number off the old one.
ba_50
I have been working with 2 trailers with different sizes. Probably got them mixed up as there are several lying around. Seals are the most difficult parts to get on the hub.
ESGWheel
Ensign
If I may, here is a good inexpensive tool to add to your collection if you do not already have one (link). And here is a how-to vid on measuring bearings and seals (link).
Also, you state “Seals are the most difficult parts to get on the hub.” how are you doing this? Reason is that I find the outer races the more challenging installation and after a while I finally got a race and seal installation kit like this one (link) that makes it all go a lot easier. While you can go crazy expensive on these types of kits, the linked one is stupid cheap but effective for the occasional use.
