nola mike
- Joined
- Apr 22, 2009
- 5,960
i've always had intermittent shifting issues with this boat. doesn't matter if i've had different outdrives, new shift cables, etc. latest episode decided to stop shifting into reverse if the idle was too low. so i started from scratch with adjusting the cables. now i have no reverse, and goes into forward after shifting back and forth a few times. not sure what the issue is. the cables were adjusted per the manual, i have the cable in the upper section of the slot. the drive shifts easily when using the cable (although it shifts at the end of its travel). 9/16" play in the lower shift cable, 3 1/8" travel from forward to reverse on the remote cable without appreciable slop. only unusual thing is that when i adjust the remote cable, the barrel is very near the end of its adjustment (i have about a turn left until i hit the stop). also, not sure what to make of the inability to shift in either direction. if i had play downstream of the lower cable, then that should show up in that first measurement, and also when i tried to shift by hand, right?
