Re: Why replace water impeller early in fall vs waiting till spring?
Since you should be removing the drive during winterization to do other maintenance (alignment and greasing the coupler splines, and you have to drain the gear lube to change it, why not go the extra step and replace the impeller while the drive is off and easier to do?
