Re: will 4.3 mercruiser engine parts fit in a chevy 4.3 block
I just finished a block swap on a 4.3, this is possible but you may have many challenges ahead of you, and the overall cost can be more than expected.
This 1988 OMC had a large crack in the lifter valley, but the crank, rods and pistons were in great condition as was the cam, lifters, etc. I used a donor 1998 truck block.
Here are some key points to compare when looking to swap blocks;
1. mechanical fuel pump Boss
2. balance shaft vs. non balance shaft
3. 6 or 10 bolt timing cover
4. steel oil pan, or aluminum oil pan
5. a Tonwanda built engine or a Romulus built engine
6. a 5/8" oil pump pickup tube or a 3/4"
That's just a few key points, but their are wide range of differences between automotive, and marine, or year model to year model, or manufacturing origin.
