Will a 1977 135hp Chrysler outboard work as a parts motor for my 1974
WinnerCougar74
Looks like the lower end is different. What else is different between a 1977 and 1974 Chrysler 135hp?
jerryjerry05
The block is probably the same, the ignition might be different, the lower unit like you said is different: I think in 77 they went to a one piece housing for the bigger motors.
Post pics of both motors?
Nordin
Jerryjerry is right about the LU, they started to use a one piece LU in 1977- 78. In 1975 some of the 135Hp was equiped with the MagnaPower II igniton until 1977.
Then they started to use the Prestolite ignition system.
Everything else except the LU and maybe the ignition system are swappable. I have a 1975 135Hp myself that I am going to restore and it has the MagnaPower I system with a belt driven distributor.
WinnerCougar74
Thanks for the replies. Can the 1977 LE and be bolted to the 1974 engine block?
Nordin
What do you mean with LE?
Lower end?
Yes you can bolt your 1974 power head to the 1977 middleg and lower end.
