will a few tire tubes float 1/2 a toon?
lucky7
would a few truvk tire tubes float 1 side of a 20' pontoon boat out of the water? enough to get it on some supports or close? or would it work out that i would need 17 or 20 of them? i was hoping that 2 0r 3 might do it.
lucky7
Re: will a few tire tubes float 1/2 a toon?
thanks.
anyone know how much air will fit in a truck tube? dont think near enough...
tashasdaddy
what are you trying to do? then you might get better ideas.
lucky7
yes, i have a leaky tube, and no way to haul out the boat. im looking to get 1 tube ou of the water to asses and hopefully seal it.
lucky7
maybe 2 55 gallon drums? if my calculations are correct, they would be good for 500 lbs of flotation each. does that sound right?
26aftcab454
you will have to temp patch hole then pump out the pontoon before you can do much of anything. that poontoon full of water must weigh tons.
good luck.
