Will a fletcher 14ft with 40 hp enging pull a tube or a skiier??
tommyk021
I am about to buy a small speed boat and want to know if it should be able to pull some1 on skis or a ring???
Thanks
skibrain
Re: Will a fletcher 14ft with 40 hp enging pull a tube or a skiier??
I have no idea what a Fletcher is, but if it is a small person on tube or skis and the boat is propped for pulling it will probably work. If a spotter is required in your area, that likely doubles the crew weight in the boat and is very significant. I grew up skiing behind 20 hp and 40 hp on small boats but I was not very big (under 140 lb at the time) Pulling a tube with the 40 hp did not work well at all.
If your primary goal is to pull skiers and tubes I would suggest getting into something with a 70 or 85 hp motor.
