Will a OMC 400 work on a V8 ?
Status
Not open for further replies.
timstiles
I have a broken driveshaft snapped off in the pinion bearing in the lower unit on my OMC 800 . I have a known good OMC 400 unit , includes everything from the bellhousing to the prop.
So far my research has shown that the drive shaft, prop shaft, and gear ratio are different . Can I run this on my V8 boat, maybe change the prop pitch to compensate, and keep on boating ? If anyone wants to trade a 800 for a 400 let me know too! : )
Boatist
Re: Will a OMC 400 work on a V8 ?
No the proper gear ratio will not be available. Also the 400 is a lighter duty unit and not designed to Handel the power of the V8. Shaft are smaller around and may just twist off.
timstiles
Looking at sterndrive.info the 400 gears are 13/26 and and the 800 gears are 14/26 , or maybe I have that reversed. That doesn't sound like much of a difference to a boat newbie. Hopefully I can find someone with a good 800 series lower.
fendersfender
400 will never hold up with a V8.......Either have yours repaired or buy a reman
KaGee
What Boatist and Scott said.
Status
