Will an electric fuel pump work to Replace VRO Pump
Stimy24
Hey guys, I want to use an electric fuel pump instead of the VRO pump, i got it running with out the VRO pump, but i think its called the Crank case pulse line(the hose coming out of the motor that has air pressure coming out of it).. can this be blocked off or does it need to be open?
I had the motor running with the VRO blocked off but the pump failed so i want to fully remove it and replace it with an electric on but i do not know what to do with that "pulse line".
any info would be greatly appreciated! i am trying to get this boat on the water tomorrow sometime.
boobie
Re: Will an electric fuel pump work to Replace VRO Pump
First off DON"T use an electric fuel pump!! Big Safety hazard !! You can put a regular pulse type fuel pump on it and mix your oil and gas. Post the model # of the mtr and we can go from there.
