Will any hour meter work on a GM engine
PSU80
Just put in a new engine (4.2L) but don't have an hour meter. Any "easy" recommendations?
dingbat
Heck, it will work without a motor...lol
Hour meters are nothing more than electric clocks. Ignition on, clock running...Forget to turn off the ignition, clock still running.
Works good to keep track of how long the ignition was on. Not so good as to how long the motor was actually running.
Pretty useless measuring device in reality.
not sure what the purpose of an hour meter is unless you do hundreds of hours of boating per year and have multiple maintenance events per year.
otherwise, the average boater never needs it because they boat less than 50 hours per year, so the "annual" maintenance is required since most maintenance things are "every 50 hours or annually"
tpenfield
Yes, hour meters are stupid, they have no idea what engine they are monitoring, as long as they are getting their input from the ignition switch.
H20Rat
I like tinytachs and their clones. Cheap tach + hour meter. They also don't require any electrical connections, just a single antenna wire wrapped around a spark plug lead.
