Re: Will CLR remove corrosion from my sterndrive?
You can repair this but you need to make sure you have anodes and the unit should be pressure tested, And no CLR is not the answer for this severe corrosion on unit, other steps are nessessary to restore this surface.
[/QUOTE]
