madman2021
- Joined
- Dec 17, 2010
- 175
I found a deal on a trojan f32 that I'm going pickup tomorrow. Also found a deal on 2 running take outs Detroit 671's. Will these engines fit in this boat or are they wayy too big.
Is this a straight drive or a V-drive. In 1985, I think they made them both ways.
If it is a V-drive your package space is even worse. Also, why convert to diesel? With that new generator needing gas you would either have to replace that or come up with a way to carry 2 fuel sources....not fun.
Seems like for the cost of a couple rebuilt 350s you could be on the water and burn a LOT of gas before you would come anywhere close to breaking even on converting to diesel.
Convert to diesel? If I can get a set of diesels for less than 10 grand why not?
10 grand buys a heck of a lot of gas. You may get those 350s running, tuned up and ready to go for a couple hundred bucks.
By the time you buy the diesels, change over the entire fuel system, modify/fabricate all the required mounting hardware and actually get the boat in the water.....never mind. Seems you made up your mind.
Madman, In 1972 and maybe a few years after Trojan had a serious problem with the f-32 I will explain as best as I can. We owned a f-25 then an f-26 then a f-28 and then we were going to buy a f-32.
We had a surveyor named Paul Flarety, who was the best in Michigan and he walked right up to the boat and said this is the first thing that we need to check.
Under the port engine he scraped the bottom paint off and there was a small crack, he then told us that Trojan would fix this problem as it was an engineering defect, we passed on the boat. What happened was that when under rough seas the crack could get so bad that the engine would fall thru the hull and sink the boat.
If I'm not mistaken when the boat was new a couple of salesmen were running one to a boat show and they died due to this failure with the boat sinking, that was a long time ago and the details are a little fuzzy but I think they are correct.
Please, please have a competent surveyor read this and check the bottom in the area that I mentioned, I think it was called the chine under the engine on the bottom of boat.
The f-32 in my opinion is the most beautiful boat on the market, good luck.
You can pm me if needed.
ANDERSON v. WHITTAKER CORP. | Leagle.com
This roused my curiosity, and I searched and searched. Finally found the lawsuit that lakegeorge refers to. Had nothing to do with any alleged hull fracture, but with a recall/redesign Trojan had initiated to redesign the engine room air vents, which were prone to scoop up water in a heavy sea. If the stern bilge pump is undersized or inoperative, the boat could conceivably take on enough to sink. The plaintiffs argued that this 'probably' contributed to the loss of the boat, while Trojan countered that there was evidence that the stern bilge pump had been removed. Court found in favor of the victims' families.
Not that any boat that size shouldn't be surveyed (it should) but I found no mention anywhere (aside from lakegeorge's post) of a hull defect. What I DID see were a couple of mentions of the boat handling very badly (severe bow steer) if weight is concentrated too far forward. One of those items specifically mentioned problems encountered with heavy diesels in the boat.
Not trying to mislead anyone. I've searched numerous combinations on google and that is the ONLY such incident I've found involving a Trojan F-32. Happened crossing Lake Michigan in 1980. All 4 aboard drowned.
I'm not saying what you wrote didn't happen, but I can't find any record of it. I DID find a few references to the air intake issue/lawsuit on other boating forums, but not a single mention of a F-32 structural defect. You know the background, so you should be able to find the documentation to support your claim.
This happened 32 years ago so I seriously doubt that I can find any back round, nor do I want to. I'm just stating what I know to be a fact and could care less what in the hell you think.
