Will i need to add a battery switch
jon2224
Yes i have a 2015 stingray 198rx im installing 1 m2750x5 channel rockford fosgate amp it will be pushing 4 6.5s m1s and a kicker 10 in sub i have the starting battery and also have a 29dc with 122ah that will be used for the amp and stereo will i need to hook up a battery switch i have a 5511e blues seas switch from a previous boat that i never installed this one has the dual isolation. Would i be ok just hooking a maintainer to the batteries or would you use the switch and combine the batteries when im running the boat i usually sit for a few hrs while the kids swim
cyclops222
I went to the Blue Sea site opened up the page about your5511E switch. not very clear about which 1 you have. 1 looks normal. Other is very confusing about operation. I would call or EMAIL blue sea about your switch.
dingbat
Im running the same setup. Whats confusing?
The switch is a simple on/off/combine for use with an ACR
There is no need to switch between batteries (battery 1/battery 2) since the ACR handles the charge function. Otherwise, it operates like a normal battery switch
