Will Low Transmission Fluid Cause Low Speed
BLOWINGSUNSHINE
Have A 21ft Boat With 105hp Turbo Diesel.i Can Only Get 2000rpm From The Engine Under Load But Have Since Noticed That The Gearbox Is Very Low On Transmission Fluid.could This Be The Cause Of Low Speed
Don S
Re: Will Low Transmission Fluid Cause Low Speed
It could if the transmission is starting to lock up from lack of lubrication.
Without any indication of type of engine and/or transmission, or year or anything else, there really isn't a way to give an kind of an accurate answer.
