Will my 120 lower unit swap to my 888 outdrive?
AWALL
I just bought a 1976 beachcraft ski boat, it has the ford 302/188hp and 888 outdrive. My lower unit has a round crack opposite of the drain in front of the water pickup. My question is can I swap a 120 lower unit onto my 888 upper housing after all they are both R drives right?
Re: Will my 120 lower unit swap to my 888 outdrive?
Ayuh,... If the splines match up, it should swap out...
Don S
Hard to say, the 888 isn't an R drive, it's a MC-1 drive, have no clue about your 120.
AWALL
how can i find out if the 120 drive is an mc-1 drive?
Don S
If you have the complete 120 outdrive, there should be a serial number on the port side of the upper.
AWALL
the serial # on the 120 drive is 4907808 198 R cant see on on the 888 drive
Don S
The 120 is from 70-77 sn range, which makes it a MC-1. The 888 Ford was only used from 71-77. So that makes both of your drives the same era and both are MC-1 drives.
