3 lite-weight oils or the heavier blend recomended by the manufacturer - tough call![]()
I remember reading on a number of sites that synthetic oil is not recommended for marine use.
My recommendation is that you use the quality, type, and blend recommended by the manufacturer for your engine. If you follow that advice and change your oil when called for, or sooner, you can't go wrong.
http://northamerica.mercurymarine.com/serviceandwarranty/mercruiserfaqs/fueloil.php
Above is what the OEM recommends for their engines.
Now, if you don't want to use that, use whatever the 'ell you want. Change the oil yearly or every 100 hrs. along with the filter and your engine will be fine.
Marine engines never die from the type of oil used.
