Will my impeller blades right themselves?
TRONMAN2000
I just replaced my seawater pump shaft seal and impeller on my 2000 VP 5.0 GL and just realized that I might have rotated the housing the wrong way before putting it all back together. CRAP! Will the blades right themselves? (I did lube them with glycerin) I Have not started it yet. I sound pretty lazy, but my back can't take much more!
Don S
Re: Will my impeller blades right themselves?
Yes, they will turn to the right direction.
TowRoper
;) looks like you'll be fine mate.
TowRoper
just funnin ya its best to put then right due to the tight fit it could damage it if facing the wrong way.:p
TowRoper
:confused: don they will? mine didnt :mad: blank blank volvos
Don S
Yea, you can have problems with those, but a 2000 5.7 will right itself. Don't compare apples and oranges. They don't use even close to the same kind of pump.
Fun Times
I agree, Also the newer style plastic housing for mercruisers bravo impellers will also right themselves, And I believe the brass style will also But I am not 100% sure on that.:)
TRONMAN2000
Thanks guys, my back feels better already just hearing that from you. I figured if I could right the vanes by turning the housing counterclockwise, my engine could right them by turning the impeller clockwise. Same difference?
Thanks again!
