Re: Will my motor charge a battery?
Guest makes a nice charger.They are "smart" chargers, its a multi stage electronic charger, each stage has its own purpose. basicly without going into full detail, the charging process is less damaging to the battery and the final stage will actually clean the battery's plates of hardened lead sulfate to help you achieve max battery life. Guest is not the only manufacturer of this type of battery charger, I just happen to own one made by Guest. They are definetly worth the extra coin, especially if you dont get a good charge from your engine. Good Luck.
