Re: will only go in reverse 50 hp johnson
sounds like you got the shift linkage back together wrong, check and make sure you got the pin back in the hole on the rod not above it, all you have to do is manualy move the belcrank on the starboard side of the motor and look at the rod make sure it is in there right. (kind of tough to see down there isnt it?)
