Will Raw Water Pump Impeller Pieces Cause Problems (3.0GS SX)
djpeters
Hi,
My In-laws have a '95 FourWinns Freedom with a 3.0gs and Cobra Drive (Volvo SX from what I understand). The engine overheated on me yesterday. I checked the raw water impeller just now and all the fins are completely gone. I want to know if I need to be concerned about where the fins are now. I am going to go out shortly and take the thermostat housing off and plan to replace the tstat and look for debris.
Is there a back-flush procedure I shoud do? If so, can someone tell me how one would do that? I plan on picking up a new impeller and tstat tomorrow. I guess i'm looking for a little guidance here if anyone else has done this.
On a side note, I was suprised that there is no pump in the outdrive itself. When everything is working correctly, does the raw water pump run dry momentarily every time its started? That's a long hose from the outdrive to the pump to have to fill everytime it seems. Is that how it works or is there a check valve somewhere that keeps things primed between starts?
Thank You.
woody66912
Re: Will Raw Water Pump Impeller Pieces Cause Problems (3.0GS SX)
Most of the pieces should be in the intake hose. the rest should be the thermostat housing. It's always best to remove the housing and thermostat those pieces like to get caught in the housing outlets that go the exhaust risers, try to account for them all.
djpeters
I just took off the thermostat housing and pulled the thermostat. I also took a few other hoses loose and there is no trace of impeller pieces anywhere. What is left of the impeller is very brittle so is it possible it slowly crumbled apart and the pieces went through?
Unless someone totally objects, i'm going to get new impeller and tstat and put it back together.
djpeters
Update:
I was able to get all the parts I needed except the gasket for the raw water pump. That should be in today. Last night I got the new t-stat in and buttoned everything up except the raw water pump. I hooked up my garden hose to the t-stat housing and ran it for about a half hour. Ran good, temp stopped right at 160. Hopefully a lake test tonight.
djpeters
The gasket came in yesterday and I got it all back together. Took it for a test ride and all is good. Went for a 2 hour ride and the temperature ran 160 the whole time.
Maclin
Good deal!
