Will the 2 lower units interchange
superman
One with EZ shift and the other cam shift. Both off Mercury 115 hp motors. Both late 70s.
Laddies
Banned
Re: Will the 2 lower units interchange
All 70s 115 gearcases were cam shift
superman
I have a motor that the lower unit that came off moves about 30 degrees each direction to shift and I have another lower unit that the shift turns almost all the way around. Will they interchange?
Laddies
Banned
Superman the reason the shaft turns around so far is you need to turn it till you find the detent for fwd gear and then turn it counter clockwise to the next detent the should be neutral and the following on should be rev. if you turn it to far in rev. then you have to turn it all the way around till you get fwd. again
superman
Thanks for the info. I will reset it and install it.
superman
Laddies: Thanks for your help. I thought I had it right but Obviously not, I went backa and did what you said and it bolted down and worked perfectly. Thanks for the help.
