will the "through the hub exhaust" props fit an18 spline chrysler outboard motor
WinnerCougar74
will the "through the hub exhaust" props fit an 18 spline chrysler outboard motor
The Force power
There are are hundreds of "through hub exhaust props" out there, so it would be impossible to answer your question with the information you're providing
This may work; Count the splines in the prop.
jerryjerry05
The old style usually doesn't work well with the new lowers.
Yet the new can work on the old as there is no exhaust exiting the prop.
Most exhaust went out the snout until the mid 90's (95+)
18 spline??? try them ???
