will this gear case fit an 08 etec? standard v6 lower unit
Sixmark
Re: will this gear case fit an 08 etec? standard v6 lower unit
Ummm NO!!!!!, what does the item description say?
budsbud662
Yes i can read, quite often parts work in different years and year range / part number is listed for direct placement.
for example a head may say its not good for a certain year because the plug is different but the bolt pattern is the same.
or a water jacket is blocked.
I thought the intelligent would realize this. but i should have figured someone would say "learn to read"
Sixmark
Had you bothered to even look up any of the information yourself then you would have known that it would not fit.......even the intelligent can do a simple web search and find that info!!!!!
Sixmark
If you were to buy from Ebay, which is where that craigslist ad redirects to and your model was not listed in the compatibility chart, then no matter what happens they can refuse to honor any warranty and you are stuck with it.
