Will this prop fit ???
macca123
A question for the prop guru's out there, I have a 40 hp mariner/ yamaha serial no 40e 6e9l 405360 a 1982 model and the prop no is 48-73136 a4 13p, I want to go to a bigger pitch so I have found this prop f10. 13x15p it is off a mercury don't know what model, will this prop fit my engine need to know as i can get it at a reasonable price.
thanksyou
regards
keith
macca123
Re: Will this prop fit ???
Abraham I have since found out it is a 2004 model off a 50hp mercury, I am now trying to find out how many teeth it has on the shaft, 2 questions for you .
1 If it has 13 tooth shaft same as mine does that mean it will fit.
2 I have to stay pretty close to the diameter of the old prop so as it will fit under the cavitation plate.
thanks
keith
steelespike
If you go to the iboats prop store and look up props for the 2 motors the description and sku numbers should tell you.If the prop is intended for your motor it will fit under the Anti vent(cavitation) plate.
I looked them up they are the same number, if one or the other is not a big foot.
macca123
Thanks for the reply, I will contact seller and check that it's not a bigfoot, if it's not then should fit.
thanks
keith
