Gromulin
- Joined
- Jul 5, 2010
- 230
I've read some of the threads on windshield spread here, and after I finished freaking out a bit, I doubt it's a bad structural issue. Everything is solid, and I'm pretty sure that it's spent most of it's life on a Trailer in a hot, dry climate. Las Vegas, to be exact.
My windshield is spread about 1/2" at the top, compared to the bottom, when you close the walk-thru window. Can the hull have "relaxed" from sitting on a trailer in 100 + degree heat for a long period of time, even if it was under a cover (gel-coat and upholstery look fine)? Just wondering since all the weight sits on the bunks near the centerline, instead of the weight being distributed if in the water.
Just curious. It's not so bad that the latch wont work, but enough to be noticeable. I kind of remember my old boat having a trim piece that could be adjusted to fill the gap...anyone heard of those?
Thanks in advance
Thanks in advance
