tractoman
Thread starter- Joined
- Jul 16, 2009
- 370
Is it OK to winterize by only draining fluids from the block, manifolds and power steering cooler and not filling with anti freeze? Secondly, I understand it is best to keep the OD down to relieve strain on the bellows when it is stored. I can only lower it to where the trim up cutout stops raising the outrdive as if I were on the water due to cranking the trailer higher in the front to allow moisture to drain out the stern. Obvously it is much lower then in trailer or full up position. Is this OK or should I dig a hole for the skeg so drop into in the ground.
Thanks,
Thanks,
