Re: Winterization at Dealer Sounds Like a Scam
You might say I once sassed a pretty good guy. Same attitude -- I know cars, what's the big deal about a boat? It was spring and he was up to his elbows in repairs from amateur winterizations. I hadn't bought a boat yet but he showed me various busted blocks, heads and outdrives plus a heaved floor with separated stringer. And he was kind (or ornery) enough to elaborate the common errors (or was it scoff the owners?).<br /><br />I remember a few good points:<br /><br />1- Read the manual -- it's not just the cooling water. For example, a bad gearcase seal can allow water intrusion and lead to a lower unit housing destroyed by freezing (outdrive or outboard).<br /><br />2- The outdrive "hub" wants lube annually and removal of the outdrive is required. Waiting too long costs MUCH more because both the engine and the outdrive must be removed just to reach the shredded $300 coupler.<br /><br />3- Rod out the lakewater passages! They are full of sand, leaves and moss which will hold water or prevent draining. Remove petcocks, they are just there to fool you (confirmed!).<br /><br />4- Get RV antifreeze into the low spots. They did NOT drain. <br /><br />5- Tip the boat, remove hull and tank plugs and decide how to keep it dry.<br /><br />6- And myriad other stuff: Water in the oil? Manifolds drained? Bellows? Hoses? What about the seawater filter and the zincs? Seafoam or Stabil -- and did you run it long enough to reach the carbs or injectors? How's the impeller and housing...<br /><br />Yeah, I do it myself (usually in the cold wind because Ive stretched the season). In fact the last outing of my first year of boating literally ended in a snowstorm so I had no choice.<br /><br />Some of the preventative stuff got held over, but his advice surely saved many woes in the spring. It was not simple or quick; I was so paranoid that I ran antifreeze through the lakewater system, drained it as if I hadn't and then worried about it until spring. <br /><br />It's a test of will to dive into the bilge to remove that already-open petcock by flashlight while soggy in snow; but I still remember how much residual water and guck came out when I wriggled the welding rod into the oil cooler and exhaust manifold drains! Hmm, wonder how much that might have cost?
