Winterization Ford 2.3 and OMC Cobra
Smiles79
Just picked up this boat, never had one before. I think I'm pretty clear on the engine side of things but was hoping someone could help point out the water drain plugs on the outdrive.
I've heard of a screw that is never to be pulled out and I want to make sure I know where that is. Is it the one behind this round cobra emblem?
Lou C
PS
the one on the port side for the pivot housing/raw water hose you will usually get water from, you may have to rod it out with a pic
the ones on the starboard side (there are 2) are there in case either the gasket between the pivot housing and drive leaks, or if the threaded fitting for the shift cable that's screwed into the back of the pivot housing leaks. Mine usually does not have water there but it's still good to check.
I add antifreeze, I feel it helps reduce corrosion but that's optional. I use Sierra PG antifreeze mixed up to provide freeze protection to about -30*F. Better than RV antifreeze by far.
Make sure to rod out all drain holes including the ones in the engine and exhaust manifold, they can be blocked by rust flakes.
PPS if those drains on the side of the pivot housing are seized up (can happen if never removed) try an impact screwdriver, if they are really stuck you can remove the 6 nuts that hold the drive to the pivot housing and pull the drive back a bit, that will let any water drain. Trapped water can and will crack housings.
Smiles79
That is exactly what I was looking for, thank you!
So there are no water drains lower down on the outdrive? Does that water drain on its own?
Lou C
yes if the drive is lowered as in your pix
