Winterize How To
Fish Canada
I think this is a excellent "how to" video for winterizing, and I like how they fog the engine. Can this same method be used on carbureted engines?
You can but with a carb engine you can get more oil in the cylinders spraying it straight into the carb. EFI's are not done this way because the oil will coat the sensors and cause issues next season.
Fish Canada
Thanks that makes sense.
drpepper68
So winterizing an older mercruiser carb engine is totally different? If I keep it in the garage where it doesnt freeze I dont have to do any of this right? Just add fuel stabilizer...
Starcraft5834
Ive got a 3.0 Mercruiser with carb too. yep, add stabilizer.. you should be good. as to in garage that don't freeze,, your good there too, as long as it don't freeze...avoid any possibility by draining the block and manifold
Ayuh,.... Exactly,..... a power outage could be a really bad day otherwise,.....
