Winterize Q
Tafflad
Normally I have my engine winterized & annual service at same time ... for a number of reasons (mainly snow related) it still isn't done.
I had fully drained the block via the 5 blue plugs ... boat is on trailer also under cover in it's own boat shed.
As this delay is on-going .... perhaps I should put in anti-freeze.
I assume leaving block with nothing in it could accelerate corrosion.
I can run up engine on muffs to get it warm, should I then simply run it in a container of 50:50 antifreeze ??
Or shall I not bother to run it up and instead fill from engine .... ?? if the latter, can somebody tell me what hose(s) I should remove to pour in the mix ?
Engine is 2007 (carb) 4.3L Mercruiser.
It is raw water cooled (without air assist drain)
Re: Winterize Q
Ayuh,... Has it been below Freezing over there yet,..??
I'd pull the Big hose off the circulating pump, 'n drain the P/S Cooler,.....
Then call it Good...
Air just Don't Freeze.....
Tafflad
Re: Winterize Q
Been around -5 (23F)at night for past 4 weeks ..
I did get engine hot, with 'salt-away' injector, then drained all 5 blue plugs ..
I'm sure I can find circulaing pump hose ...is the p/s cooler obvious ? .... I'll admit to not knowing where it is.
Boat is bow up, (well up) and drive is down.
stonyloam
Re: Winterize Q
Remember what Benny Hill says happens when you assume?:D Rust needs moisture and a continuous supply of oxygen. If you drain and put the plugs back in you cut off the oxygen supply and limit rusting. If you got all the water out, I would not fool around with the AF. Besides if you are talking about a 50:50 mix of automotive antifreeze you will have a toxic (not to mention illegal) mess in the spring, if you do use AF use pink RV stuff. Just my opinion. Good luck.
