rweboard67
Thread starter- Joined
- Oct 14, 2009
- 49
how much time do i have to get my outboard winterized ? in new england !
about 10 minutes.
I'd at least be sure no water in the lower unit, gonna be cold up there this weekend.
Hi Bob, hey I found that if you jack the trailer up in the front and tilt the motor all the way down and in that an additional 1/2 cup of water will run out. At least it does on my Mariner and my E-Tec. Might just be the difference in the way all of our trailers sit. Might be worth checking.IF the outboard is stored straight up & down (not tilted up at an angle) then the water will be drained out. If it is tilted it could trap and hold water so I always store them in the down position.
Winterizing the outboard consists of fogging the cylinders, making sure the carbs are empty of fuel, and changing the lower unit oil.
Get the proper manual and do all the work yourself in under 30 minutes and save yourself a ton of money![]()
